DorianL
2 years agoRTL Simulation failed : Enqueue process failed
Hi, I tried to simulate my IP which is a video processing and when i compile and run emulation, everything work fine but then i tried to compile and run the RTL Simulation but unfortunately i can co...
whitepau_altera
Contributor
2 years agothat error sometimes shows up in designs that use host pipes to get data into/out of your kernels (like you would in a video design that uses streaming interfaces for I/O)
Have you been able to successfully compile our Convolution 2D code sample?
https://github.com/oneapi-src/oneAPI-samples/tree/development/DirectProgramming/C%2B%2BSYCL_FPGA/ReferenceDesigns/convolution2d
Also make sure you are using the latest 2024.1 compiler.
