Titanameda
6 years agoRTL opencl Run time errors
Hi. Compiling RTL opencl example1, 1.compiling host code (via make file) is completed 2. while Running (host executable :host ) get the following error Querying device for info: ============...
MEIYAN_L_Intel
6 years agoHi,
Can you try to install OpenVino for MUSTANG-F100-A10 by follow the link below:
https://docs.openvinotoolkit.org/latest/_docs_install_guides_VisionAcceleratorFPGA_Configure_2019R3.html
Do you have two board which is MUSTANG F100-A10 and Arria 10GX FPGA board as you had mentioned you want to install both BSP? Since these two board use different BSP and compiler software.
