RTL opencl Run time errors
SECTION 1:INSTALLING BSP
aocl install /opt/intelFPGA_pro/18.1/hld/board/a10_ref/
aocl install: Adding the board package /opt/intelFPGA_pro/18.1/hld/board/a10_ref to the list of installed pckages
aocl install: Setting up FCD
aocl install: Running install from /opt/intelFPGA_pro/18.1/hld/board/a10_ref/linux64/libexec
Looking for kernel source files in /lib/modules/4.15.0-70-generic/build
Using kernel source files from /lib/modules/4.15.0-70-generic/build
Building driver for BSP with name a10_ref
make: Entering directory '/usr/src/linux-headers-4.15.0-70-generic'
CC [M] /tmp/opencl_driver_L2D8cb/aclpci_queue.o
CC [M] /tmp/opencl_driver_L2D8cb/aclpci.o
CC [M] /tmp/opencl_driver_L2D8cb/aclpci_fileio.o
CC [M] /tmp/opencl_driver_L2D8cb/aclpci_dma.o
CC [M] /tmp/opencl_driver_L2D8cb/aclpci_pr.o
CC [M] /tmp/opencl_driver_L2D8cb/aclpci_cmd.o
LD [M] /tmp/opencl_driver_L2D8cb/aclpci_a10_ref_drv.o
Building modules, stage 2.
MODPOST 1 modules
CC /tmp/opencl_driver_L2D8cb/aclpci_a10_ref_drv.mod.o
LD [M] /tmp/opencl_driver_L2D8cb/aclpci_a10_ref_drv.ko
make: Leaving directory '/usr/src/linux-headers-4.15.0-70-generic'
SECTION 2: Checking
here while checking , the following errors are obtained.
aocl diagnose
/opt/altera/aocl-pro-rte/aclrte-linux64/board/a10_1150_sg1/linux64/libexec/diagnose: error while loading shared libraries: libaltera_a10_1150_sg1_mmd.so: cannot open shared object file: No such file or directory
Warning:
No devices attached for package:
Vendor: Intel(R) Corporation
Found no active device installed on the host machine.
Please make sure to:
1. Set the environment variable AOCL_BOARD_PACKAGE_ROOT to the correct board package.
2. Install the driver from the selected board package.
3. Properly install the device in the host machine.
4. Configure the device with a supported OpenCL design.
5. Reboot the machine if the PCI Express link failed.
DIAGNOSTIC_FAILED
Warning:
Warning:
/home/tata/Sharath/hddlf_1150_sg1
Call "aocl diagnose <device-names>" to run diagnose for specified devices
Call "aocl diagnose all" to run diagnose for all devices
The same error, device not found exists .
