Titanameda
6 years agoRTL opencl Run time errors
Hi. Compiling RTL opencl example1, 1.compiling host code (via make file) is completed 2. while Running (host executable :host ) get the following error Querying device for info: ============...
HRZ
6 years agoHave you set up your board correctly? Does "aocl diagnose" pass? That error happens when the runtime cannot detect your board.
- Titanameda6 years ago
I am just emulating , I believe that aocl diagnose is to test if the board is connected
- HRZ6 years ago
Then, are you passing "CL_CONTEXT_EMULATOR_DEVICE_ALTERA=1" (for v16.1.2 and below) or "CL_CONTEXT_EMULATOR_DEVICE_INTELFPGA=1" (for v17.0.0 and above) when running the binary compile for emulation?
This is what I have !
- HRZ6 years ago
Which version of the compiler are you using? Have you followed the instructions of Section 8 in the Programming Guide?
