resume x2goclient session
All terminal and X2go sessions with no keyboard activity seem to terminate in 20-30 minutes. We highly encourage running all the steps in batch mode. regards, Larry
Larry,
Can you please elaborate or point me to instructions for running in batch mode? My steps are pretty simple.
- devcloud_login
- ssh -L "..." from another terminal
- Launch X2GOClient
How does batch mode apply to the above?
- Lawrence_L_Intel5 years ago
refer to this document: https://github.com/intel/FPGA-Devcloud/tree/master/main/Devcloud_Access_Instructions#devcloud-access-instructions
and look for the section submitting batch jobs. use this link for access to various quick start guides for the supported workload processing: https://github.com/intel/FPGA-Devcloud/tree/master/main/QuickStartGuides
Find the flow you are working on there is a starting point batch script. Make sure if you are downloading the batch scripts and files to use the "raw" format.
Let me know if this works out ok for you.
Larry
- ashishkkaul5 years ago
Larry,
I understand that devcloud_login -b will run in batch mode. Thanks for the pointer.
However, the question in this case is about failing to be able to use the Resume button of the X2GOClient. Let me try running devcloud in batch mode and see if it addresses the issue I am seeing with the X2GOClient.
Ashish
Larry,
Running in batch mode does not help solve this problem.
