report shows no DSP usage for OpenCL kernel
Hello, I'm new to OpenCL for fpgas, I wrote this code for matrix and vector multiplication, after compiling with aoc 19.3, the report shows that no DSP is used for calculation of the kernel, anyone know what I'm doing wrong?
__kernel
void matvec(global float* restrict matrix_a,
global float* restrict vectors_b,
global float* restrict result,
uint n,
uint vec_count)
float localmatrix[BLOCK_SIZE][BLOCK_SIZE];
float localvector[BLOCK_SIZE];
float localresult[BLOCK_SIZE];
float presult[II_CYCLES+1];
#pragma unroll 16
for(uint e=0 ; e<n ; e++)
result[e] = 0;
//iteration over matrix blocks rows
uint bi = 0;
for(uint bi=0 ; bi<n ; bi+=BLOCK_SIZE)
//initializing the localresult
#pragma unroll
localresult[e] = 0;
//iteration over matrix blocks colomns
uint bj = 0;
for(uint bj=0 ; bj<n ; bj+=BLOCK_SIZE)
//loading block of matrix to local
#pragma unroll 16
for(uint ei=0 ; ei<BLOCK_SIZE ; ei++)
for(uint ej=0 ; ej<BLOCK_SIZE ; ej++)
localmatrix[ei][ej] = matrix_a[(bi+ei)*n+(bj+ej)];
//itteration over vectors
for(uint k=0 ; k<vec_count ; k++)
//loading one block of one vector to local
#pragma unroll 16
for(uint e=0 ; e<BLOCK_SIZE ; e++)
localvector[e] = vectors_b[k*n+(bj+e)];
//***localresult[j] += localmatrix[i][j] * localvector[j]***
//iteration over matrix colomns
for(uint i=0 ; i<BLOCK_SIZE ; i++)
//initializing presult
#pragma unroll
for(uint e=0 ; e<II_CYCLES+1 ; e++)
presult[e] = 0;
//iteration over matrix rows
for(uint j=0 ; j<BLOCK_SIZE ; j++)
//localresult[i] += localmatrix[i][j] * localvector[j];
presult[II_CYCLES] = localmatrix[i][j] * localvector[j] + presult[0];
#pragma unroll
for(uint e = 0 ; e<II_CYCLES+1 ; e++)
presult[e] = presult[e+1];
#pragma unroll
localresult[i] += presult[e];
//Writing the block of result back to main memory
#pragma unroll 16
result [bi+e] = localresult[e];
}10 Replies
- MEIYAN_L_Intel
I would need some time to check internally about the information of DSP block implementation.
- amrmesh
- HRZ
Have you verified the functional correctness of your code using emulation? It seems the v19.3 compiler is optimizing out most of your code. However, v16.1.2 which I still use for my main development behaves differently and does not optimize out your code but it generates very helpful warnings that could help finding the problem in your code:
test.cl:28: Compiler Warning: Full unrolling of the loop is requested but the loop bounds cannot be determined. The loop is not unrolled in kernel matvec test.cl:67: Compiler Warning: removing out-of-bounds accesses to presultEven thought v19.3 also generates the first warning, it does not generate the second one which could in fact be the source of your problem. It is possible that v19.3 is assigning a value of zero to the out-of-bound index and since you are shifting the buffer, it is assuming the whole buffer is being zeroed out and hence, it is optimizing out the computation in your kernel. Maybe @MeiYanL_Intel can elaborate why the newer versions of the compiler are excluding such critical warnings, forcing programmers to run in circles trying to discover issues in their code.
- amrmesh
Thank you very much for your time testing my code,
for functional correctness, the host code has a method to verify it, but apparently, that code also has some problems since it passed that test.
I got your point, and thanks, I will change the inner loop to see if the it will fix the problem,
a fast test (removing the shift register) proves your point is correct, by removing shift register, the report shows some DSP usage,
The strange thing is that even in the report there is no warning about this out-of-bound access !
- amrmesh
Hello again,
Sorry, I don't understand why at line 67 the compiler complains about out-of-bounds, do you know which part causes out-of-bounds access?
at first I thought I'm mixing shift register size with block size, but I don't see any problem with that, do you know which part causing it?
- HRZ
Sorry, I had to manually define BLOCK_SIZE and II_CYCLES to test your code and forgot to adjust the line numbers accordingly. You should deduct 3 from the line numbers I posted above to match your code. The second warning is on line 64 on your code where "presult[e+1]" would be out of bounds for e=II_CYCLES.
