report shows no DSP usage for OpenCL kernel
Have you verified the functional correctness of your code using emulation? It seems the v19.3 compiler is optimizing out most of your code. However, v16.1.2 which I still use for my main development behaves differently and does not optimize out your code but it generates very helpful warnings that could help finding the problem in your code:
test.cl:28: Compiler Warning: Full unrolling of the loop is requested but the loop bounds cannot be determined. The loop is not unrolled in kernel matvec
test.cl:67: Compiler Warning: removing out-of-bounds accesses to presultEven thought v19.3 also generates the first warning, it does not generate the second one which could in fact be the source of your problem. It is possible that v19.3 is assigning a value of zero to the out-of-bound index and since you are shifting the buffer, it is assuming the whole buffer is being zeroed out and hence, it is optimizing out the computation in your kernel. Maybe @MeiYanL_Intel can elaborate why the newer versions of the compiler are excluding such critical warnings, forcing programmers to run in circles trying to discover issues in their code.
- amrmesh6 years ago
Thank you very much for your time testing my code,
for functional correctness, the host code has a method to verify it, but apparently, that code also has some problems since it passed that test.
I got your point, and thanks, I will change the inner loop to see if the it will fix the problem,
a fast test (removing the shift register) proves your point is correct, by removing shift register, the report shows some DSP usage,
The strange thing is that even in the report there is no warning about this out-of-bound access !
Hello again,
Sorry, I don't understand why at line 67 the compiler complains about out-of-bounds, do you know which part causes out-of-bounds access?
at first I thought I'm mixing shift register size with block size, but I don't see any problem with that, do you know which part causing it?
- HRZ6 years ago
Sorry, I had to manually define BLOCK_SIZE and II_CYCLES to test your code and forgot to adjust the line numbers accordingly. You should deduct 3 from the line numbers I posted above to match your code. The second warning is on line 64 on your code where "presult[e+1]" would be out of bounds for e=II_CYCLES.
Thanks for your reply,
After fixing the out of bound access, report generation takes long time,
"aoc: Optimizing and doing static analysis of code..."
at this stage the compiler seems having a hard time trying to optimize the code, do you know why this is happ
#define II_CYCLES 16 #define BLOCK_SIZE 64 __kernel void matvec(global float* restrict matrix_a, global float* restrict vectors_b, global float* restrict result, uint n, uint vec_count) { float localmatrix[BLOCK_SIZE][BLOCK_SIZE]; float localvector[BLOCK_SIZE]; float localresult[BLOCK_SIZE]; float presult[II_CYCLES+1]; #pragma unroll 16 for(uint e=0 ; e<n ; e++) result[e] = 0; //iteration over matrix blocks rows uint bi = 0; for(uint bi=0 ; bi<n ; bi+=BLOCK_SIZE) { //initializing the localresult #pragma unroll for(uint e=0 ; e<BLOCK_SIZE ; e++) localresult[e] = 0; //iteration over matrix blocks colomns uint bj = 0; for(uint bj=0 ; bj<n ; bj+=BLOCK_SIZE) { //loading block of matrix to local #pragma unroll 16 for(uint ei=0 ; ei<BLOCK_SIZE ; ei++) for(uint ej=0 ; ej<BLOCK_SIZE ; ej++) localmatrix[ei][ej] = matrix_a[(bi+ei)*n+(bj+ej)]; //itteration over vectors for(uint k=0 ; k<vec_count ; k++) { //loading one block of one vector to local #pragma unroll 16 for(uint e=0 ; e<BLOCK_SIZE ; e++) localvector[e] = vectors_b[k*n+(bj+e)]; //***localresult[j] += localmatrix[i][j] * localvector[j]*** //iteration over matrix colomns for(uint i=0 ; i<BLOCK_SIZE ; i++) { //initializing presult #pragma unroll for(uint e=0 ; e<II_CYCLES+1 ; e++) presult[e] = 0; //iteration over matrix rows for(uint j=0 ; j<BLOCK_SIZE ; j++) { //localresult[i] += localmatrix[i][j] * localvector[j]; presult[II_CYCLES] = presult[0] + localmatrix[i][j] * localvector[j]; #pragma unroll for(uint e = 0 ; e<II_CYCLES ; e++) presult[e] = presult[e+1]; } #pragma unroll for(uint e = 0 ; e<II_CYCLES ; e++) localresult[i] += presult[e]; } } } //Writing the block of result back to main memory #pragma unroll 16 for(uint e=0 ; e<BLOCK_SIZE ; e++) result [bi+e] = localresult[e]; } }ening? and is this long report generation time normal? or I'm doing something wrong again?
- HRZ6 years ago
I just put your new code into the v19.3 compiler on my environment targeting Arria 10 and the OpenCL compilation finished in less than a minute and the report was generated. How long does it take on your side? I have had cases where the OpenCL compilation takes even more than half an hour, but that is for some very specific cases. The compilation time will also depend on your processor speed.
P.S. What FPGA are you targeting and what compiler version are you using?
