Remote SigntalTap setup issue on Intel PAC Arria10
Dear Sir/madam,
I am running the example nlb_mode_0_stp on Intel PAC arria10 card.
the purpose is try remote signaltap debug function based on vendor provided example and Accelerator Function Unit Developers Guide for Intel FPGA Programmable Acceleration Card.
the operation on the debug target host with the PAC installed worked good as I excpected
[root@fig01 samples]# ls
dma_afu hello_afu nlb_mode_0 README
eth_e2e_e10 hello_intr_afu nlb_mode_0_stp streaming_dma_afu
eth_e2e_e40 hello_mem_afu nlb_mode_3
[root@fig01 samples]# sudo fpgaconf nlb_mode_0_stp/bin/nlb_mode_0_stp.gbs
[root@fig01 samples]# sudo mmlink -P -B
------- Command line Input START ----
Bus : -1
Device : -1
Function : -1
Socket-id : -1
Port : 0
IP address : 0.0.0.0
------- Command line Input END ----
PORT Resource found.
Remote STP : Assert Reset
Remote STP : De-Assert Reset
Read signature value 53797343 to hw
Read version value 1 to hw
Read write fifo capacity value 32 to hw
m_listen: 4
listening on ip: 0.0.0.0; port: 0
^Z
[1]+ Stopped sudo mmlink -P -B
-----------------------------the end of target host----------------
below is operation on remote debug host, where the system_consule is not recognized as below for some reason.
I did check the PATH environment variable setting ,it looks setting correctly, Any suggestion for this issue?
thanks
Jim
- User1582192733150209
the information from the remote debug host
Microsoft Windows [Version 10.0.15063]
(c) 2017 Microsoft Corporation. All rights reserved.
C:\Users\a1228079>cd D:\Jimlin\FPGA\dev kits\PAC_Arria10GX\example\nlb_mode_0_stp
D:\Jimlin\FPGA\dev kits\PAC_Arria10GX\example\nlb_mode_0_stp>system_console --rc_script=mmlink_setup_profiled.tcl remote_debug.sof 192.168.111.204 3333
'system_console' is not recognized as an internal or external command,
operable program or batch file.
I found a wrong spelling for system_console, but after I changed it to correct one system-console ,,issue is still there as below
D:\Jimlin\FPGA\dev kits\PAC_Arria10GX\example\nlb_mode_0_stp>system-console --rc_script=mmlink_setup_profiled.tcl remote_debug.sof 192.168.111.204 3333
'system-console' is not recognized as an internal or external command,
I have found that command not being recognized issue was caused by PATH environment variable.
On the 37 of the AFU Developer’s Guide for Intel FPGA Programmable Acceleration Card , it says your PATH environment variable on the remote
debug host is setup to point to the following location in the Intel Quartus Prime Pro Edition installation:
<installation-path>/<q-edition>/sopc_builder/bin
Actually, the PATH should be <installation-path>/<q-edition>/quartus/sopc_builder/bin
there is a middle directory quartus between /<q-edition> and /sopc_builder.
hope user manual can be more accurate and save customer time
thanks
Jim
- MEIYAN_L_Intel
Thank you for your information.
I will report this to the developer.
