Matt1
7 years agoReference/Example software (C/C++-codes) for NIOSII processor which is interfaced with intel MDIO IP
I am trying to configure an Ethernet PHY using MDIO . The MDIO lines of the Ethernet PHY is be connected to the intel MDIO IP in FPGA similar to the connection available in cyclone V GT evaluation b...
Matt1
7 years agohello Lim,
Thanks for the support.
I am a bit confused with the registers address especially offset registers address;0x20 and 0x21.
should I need to use the offset Register address or the byte address?
- SengKok_L_Intel7 years ago
If you use the IORD or IOWR macro, you can use the offset registers address.
Regards -SK
