uniqueMR
2 years agoTypical way of loading runtime to Arm core (HPS)
Hi, I'm wondering what is the typical way to load runtime executable to FPGA once I build host and device by oneAPI. I followed Agilex™ 7 FPGA I-Series Development Kit (2x R-Tile and 1x F-Tile) t...
Kevin_Xu_Intel
2 years agoHi Runlong,
I was unable to local a pre-build BSP/ASP for the I-Series devkit. The best I can find is a pre build FIM for this devkit:
Go to https://github.com/OFS/ofs-agx7-pcie-attach/releases/tag/ofs-2024.1-1, and download iseries-1x400-images_ofs-2024-1-1.tar.gz
This FIM should allows you to skip section 2.2 entirely, and it is the most time consuming steps in the process of creating BSP/ASP.
Let me know if you need any help generating BSP/ASP.
-Kevin
uniqueMR
2 years agoHi Kevin,
Thank you for providing the resources. I will try to generate BSP/ASP based on the FIM and let you know if there are other problems.
Runlong
