Typical way of loading runtime to Arm core (HPS)
Hi Runlong,
I can work on getting a BSP/ASP for the I-serial Devkit. But i want to mention:
- It's not going to work with the ARM host you mentioned, only with an x86 host.
- Even if we can generate a BSP/ASP that supports ARM core, the oneAPI runtime still won't work on ARM.
- If running with ARM is a hard requirement, the only way I can think of is to export your oneAPI design as an RTL IP, and connect it to the HPS ARM core in Quartus Platform Designer.
-Kevin
Hi Kevin,
Thank you so much for your time and effort. Yes, using ARM host is NOT a strong requirements for me at this point. I mentioned the ARM core just because I related it to my other project experience in the past. In the end, I will follow what oneAPI workflow expects me to do. I really appreciate that you can help me with BSP/ASP for I-series Devkit.
Runlong
- Kevin_Xu_Intel2 years ago
Hi Runlong,
I was unable to local a pre-build BSP/ASP for the I-Series devkit. The best I can find is a pre build FIM for this devkit:
Go to https://github.com/OFS/ofs-agx7-pcie-attach/releases/tag/ofs-2024.1-1, and download iseries-1x400-images_ofs-2024-1-1.tar.gz
This FIM should allows you to skip section 2.2 entirely, and it is the most time consuming steps in the process of creating BSP/ASP.
Let me know if you need any help generating BSP/ASP.
-Kevin
- uniqueMR2 years ago
Hi Kevin,
Thank you for providing the resources. I will try to generate BSP/ASP based on the FIM and let you know if there are other problems.
Runlong
