SDC constraints with native module for OpenCL
Thanks for replying,
The issue is that working with OpenCL, I cannot edit the generated Quartus Project itself. It is generated by aoc in the process of an OpenCL compile, from an xml file that describes the module. In that xml I must specify the files that are needed for my module: verilog files, vhd files, memory files, etc. And then when it compiles it just copies the necessary files to a fresh Quartus Project and executes the necessary tcl scripts for OpenCL compilation. The thing is that it's really picky about the accepted file types, accepting only these files, and not for example .qip files or .sdc files. I was just looking to see if there's a workaround I can use, even perhaps going as far as using filesystem events to detect and edit the generated top.sdc before quartus reads it.
Kind regards,
Lennart
