DorianL
2 years agoRTL Simulation failed : Enqueue process failed
Hi, I tried to simulate my IP which is a video processing and when i compile and run emulation, everything work fine but then i tried to compile and run the RTL Simulation but unfortunately i can co...
ZH_Intel
2 years agoHi Dorian,
Good day.
I wish to follow up with you about this case.
I would like to get update on my previous reply.
1. May I know which device and board you are using for your project?
2. When you mention Video processing, which Video IP are you using for your project?
3. May I know did you generate the design example or custom design?
4. Could you share with us your design?
5. Could you share with me your which Quartus version and operating system you are using for your project? We would like to replicate the error from our end to further identify the issue.
Hoping to hear back from you so that we can proceed for next step.
Thank you.
ZH_Intel
