msaideroglu
2 years agoOpenCL host failed
Hi, I'm using Arria10 DevKit to run OpenCL on it with OpenCL SDK. I followed the guide carefully however aocl flash acl0 boardtest.aocx gives Device not part of know packages. --------------------...
whitepau_altera
Contributor
2 years agoYou are correct, we stopped supporting those cards with new OpenCL BSPs several years ago.
1. Have you tried using one of the supported operating systems? If you don't want to pay for RHEL, you may also use the free equivalent, CentOS. This is most likely to work as it is the OS we developed those tools with internally.
2. Do you have a link to this code update that you used?
msaideroglu
2 years agoHi,
the link is:
If there is no other alternative solution, I will give a try with CentOS.
