oneAPI FPGA hardware error
The nodes are "u80211@s001-n018".
The issuse still persist.
It's a sample in github,vecter-add. I don't change any code.
build_fpga_hw.sh
#!/bin/bash
source /opt/intel/inteloneapi/setvars.sh
make hw -f Makefile.fpga
run_fpga_hw.sh
#!/bin/bash
make run_hw -f Makefile.fpga
build_fpga_hw_sh.sh.e952850
quartus_sh: error while loading shared libraries: libncurses.so.5: cannot open shared object file: No such file or directory
Error: The patches required to compile for the target board (0.05dcp) is not installed for the following Quartus:
/glob/development-tools/versions/oneapi/2021.3/inteloneapi/intelfpgadpcpp/2021.3.0/QuartusPrimePro/19.2/quartus/bin/quartus_sh
dpcpp: error: fpga compiler command failed with exit code 1 (use -v to see invocation)
make: *** [Makefile.fpga:30: vector-add-buffers.fpga] Error 1
- BoonBengT_Altera5 years ago
Moderator
Hi @JInxuanBen,
It seems that the mention nodes are not part of the standard devcloud nodes.
And sometime running the qsub batch job command on the headnodes might cause some issues where command are executed in the non supported nodes.
Hence would suggest to use the 'devcloud_login' command and select the desire nodes followed by running the design example.
Hope that helps.Best Wishes
BB - BoonBengT_Altera5 years ago
Moderator
Hi @JInxuanBen,
Good day, just checking in to see if there is any further doubts in regards to this matter.
Hope we have clarify your doubts.Best Wishes
Moderator
Hi @JInxuanBen,
Greetings, as we do not receive any further clarification on what is provided. Hence thread will no longer monitor this thread. For new queries, please feel free to open a new thread and we will be right with you. Pleasure having you here.
Best Wishes
BB
