JInxuanBen
5 years agooneAPI FPGA hardware error
When I tried to run oneAPI samples on devcloud, it shows error below, but I can run them before. I didn't make any changes.
quartus_sh: error while loading shared libraries: libncurses.so.5: canno...
JInxuanBen
5 years agoEverytime I try "qsub -l nodes=1:fpga_runtime:arria10:ppn=2 -d . run_fpga_hw.sh" or make hardware
the error below will show.
quartus_sh: error while loading shared libraries: libncurses.so.5: cannot open shared object file: No such file or directory
Error: The patches required to compile for the target board (0.05dcp) is not installed for the following Quartus:
/glob/development-tools/versions/oneapi/2021.3/inteloneapi/intelfpgadpcpp/2021.3.0/QuartusPrimePro/19.2/quartus/bin/quartus_sh
dpcpp: error: fpga compiler command failed with exit code 1 (use -v to see invocation)
make: *** [Makefile.fpga:30: vector-add-buffers.fpga] Error 1
JInxuanBen
5 years agoAnd I tried to find the file 'libncurses.so.5'. This file doesn't exist. I only found 'libncurses.so.6'.
