Mopplikus
3 years agoIntel HLS - high load / store latency
I am in the process of benchmarking a few common HLS tools, and I'm having some issues with Intel HLS. I've implemented a simple histogram to test the tool, however in the test-fpga report I...
Mopplikus
3 years agoUpdate: I found a solution to my problem. It turns out that I need to initialize the memory on-board inside a component, since initializing it in the main function probably assumes that the loads and stores go through the board's I/O instead of the embedded memory. Moving the initialization inside the component solved the issue and brought it to an expected 1 cycle latency.
