Thank you for the clarification.
Is there any example that I can reference to?
Also a little more about specifying the buffer location would be great.
I don't think we have any public examples on using HBM. The only one I know is by Bittware and you will have to requests for the source code: https://www.bittware.com/resources/hbm2-2d-fft-oneapi/
If you have a HBM enabled board, the manufactory might have example that works specifically for the board.
If you are using oneAPI HLS flow (to generate IP), you will need to add HBM when you intergrade your IP in Quartus/Platform Designer
If you are using oneAPI full acceleration flow, try follwing this doc on access heterogeneous memory: https://www.intel.com/content/www/us/en/docs/oneapi-fpga-add-on/developer-guide/2024-1/partition-buffer-diff-mem.html
