How to use OpenVino to recognize Intel Agilex® 7 Device
Hi, I found a script to query the devices, it seems it cannot find the device:
yawen@yawen-desktop-pc:~$ python3 /opt/intel/openvino_2023.2.0/samples/python/hello_query_device/hello_query_device.py
[ INFO ] Available devices:
[ INFO ] CPU :
[ INFO ] SUPPORTED_PROPERTIES:
[ INFO ] AVAILABLE_DEVICES:
[ INFO ] RANGE_FOR_ASYNC_INFER_REQUESTS: 1, 1, 1
[ INFO ] RANGE_FOR_STREAMS: 1, 16
[ INFO ] FULL_DEVICE_NAME: AMD Ryzen 7 5700G with Radeon Graphics
[ INFO ] OPTIMIZATION_CAPABILITIES: FP32, FP16, INT8, BIN, EXPORT_IMPORT
[ INFO ] NUM_STREAMS: 1
[ INFO ] AFFINITY: Affinity.CORE
[ INFO ] INFERENCE_NUM_THREADS: 0
[ INFO ] PERF_COUNT: False
[ INFO ] INFERENCE_PRECISION_HINT: <Type: 'float32'>
[ INFO ] PERFORMANCE_HINT: PerformanceMode.LATENCY
[ INFO ] EXECUTION_MODE_HINT: ExecutionMode.PERFORMANCE
[ INFO ] PERFORMANCE_HINT_NUM_REQUESTS: 0
[ INFO ] ENABLE_CPU_PINNING: True
[ INFO ] SCHEDULING_CORE_TYPE: SchedulingCoreType.ANY_CORE
[ INFO ] ENABLE_HYPER_THREADING: True
[ INFO ] DEVICE_ID:
[ INFO ] CPU_DENORMALS_OPTIMIZATION: False
[ INFO ] CPU_SPARSE_WEIGHTS_DECOMPRESSION_RATE: 1.0
[ INFO ]
[ INFO ] GNA :
[ INFO ] AVAILABLE_DEVICES: GNA_SW
[ INFO ] OPTIMAL_NUMBER_OF_INFER_REQUESTS: 1
[ INFO ] OPTIMIZATION_CAPABILITIES: INT16, INT8, EXPORT_IMPORT
[ INFO ] FULL_DEVICE_NAME: GNA_SW
[ INFO ] GNA_LIBRARY_FULL_VERSION: 3.5.0.2116
[ INFO ] GNA_DEVICE_MODE: GNA_SW_EXACT
[ INFO ] LOG_LEVEL: LOG_NONE
[ INFO ] EXECUTION_DEVICES: GNA
[ INFO ] GNA_SCALE_FACTOR_PER_INPUT: UNSUPPORTED TYPE
[ INFO ] GNA_FIRMWARE_MODEL_IMAGE:
[ INFO ] GNA_HW_EXECUTION_TARGET: UNSUPPORTED TYPE
[ INFO ] GNA_HW_COMPILE_TARGET: UNSUPPORTED TYPE
[ INFO ] GNA_PWL_DESIGN_ALGORITHM: UNSUPPORTED TYPE
[ INFO ] GNA_PWL_MAX_ERROR_PERCENT: 1.000000
[ INFO ] INFERENCE_PRECISION_HINT: <Type: 'undefined'>
[ INFO ] EXECUTION_MODE_HINT: ACCURACY
[ INFO ] PERFORMANCE_HINT_NUM_REQUESTS: 1
