High Level Synthesis (HLS) Counter Example HLS Generate testbench QSYS system FAILED
- 4 years ago
Hello again.
I couldn't work on this job for a while. After trying your recommendations, I realized that I cannot create a regular Quartus project because my machine does not run Quartus well as it is too old. When I tried the same procedure on a newer machine I was able to make HLS work.
Thanks a lot for your help.
Hi @anil007,
Thank you for posting in Intel community forum, hope all is well and apologies for the delayed in response.
My guess is the error seems to be complaining about some missing connection in the qsys design.
Please do check if you did installed the CycloneV device when installing quartus.
Just to clarify does the Arria10 compilation able to complete?
Hope to hear from you soon.
Best Wishes
BB
I have a dedicated directory named Altera and I have all the installation files in that directory. The files in that directory are
- cyclonev-21.1.1.850.qdz
- HLSProSetup-22.2.0.94-windows.exe
- QuartusLiteSetup-21.1.1.850-windows.exe
- QuartusProgrammerSetup-21.1.1.850-windows.exe
- QuestaSetup-21.1.1.850-windows.exe
I ran QuartusLiteSetup-21.1.1.850-windows.exe installed everything except for hls by choosing the installtion step. I couldn't install HLS because it didn't show up during the installation. Then I installed HLS after the installation of Quartus is done. Now that you asked me to check if CycloneV is installed, I tried to ran QuartusLiteSetup exe file and by choosing upgrade I checked that CycloneV is installed.
As I have Quartus Prime Lite, I don't have access to Arria10 devices so I didn't even downloaded them. When I try it, I get "Arria10 is not supported in Quartus Standard Edition" error. When I check the fpga download center Quartus Prime Lite 21.1 individual files page, I couldn't see Arria10 qdz file. Would you like me to download Arria10 qdz file from other versions of Quartus Prime and try to install it and try hls with Arria10 after installing it?
Thanks for answering,
Anıl
