Global hls_singlepump?
- 3 years ago
Hi @ost,
Noted with thanks for the explanation and your patients, after some discussion alignment, unfortunately yes you are right. Short answer to global method of hls_singlepump are not possible at the moment for post compilation.
Please do let us know if there is anything else we can clarify with.
BB
Hi @ost,
Apologies for the confusion on the last post.
Quick follow on the previously clarification does the hls_singlepump suggestion previously applicable for your situation?
BB
Hi BB
The answer at 13-09-2023 does not answer my question in a clear manner. I need to know if there is a global way to do hls_singlepump to prevent any possible 2x clock interface. There is no way to tell if arrays will be implemented as single or doublepump until compiled and verified. I already know that I can apply hls_singlepump to arrays, but pre compilation, I can not tell what arrays will be implemented in memory, registers or even flattened out and removed. I just need to tell the compiler to stay away from 2x clock domain in general, because my architecture does not have a 2x clock available.
I guess the answer to my question is no then.
