giulio2
4 years agoFPGA Build fail on Devcloud
I'm trying to compile a project on FPGA Hardware on Devcloud.
following these steps:
qsub -I -l nodes=1:fpga_compile:ppn=2 -l walltime=24:00:00
source /opt/intel/inteloneapi/setvars.sh...
HRZ
4 years agoIt seems like the process is getting killed, likely due to lack of enough memory. FPGA synthesis requires a very large amount of memory. Do you have the amount of memory recommended below on the machine you are performing the synthesis on?
https://www.intel.com/content/www/us/en/docs/programmable/683706/21-4/memory-recommendations.html
giulio2
4 years agoHello,
I'm compiling on Devcloud, this is the result of the "free" command:
total used free shared buff/cache available
Mem: 16037092 4326092 852364 3360 10858636 11420228
Swap: 999420 531948 467472
I'm targeting "intel_s10sx_pac:pac_s10"
- HRZ4 years ago
That machine only has 16 GB of memory, that is not even remotely enough to synthesize a design for Stratix 10. Doesn't DevCloud have specific nodes for synthesis?
