Kevin_Xu_Intel
2 years agoHi @dgaranda,
I was able to compile the source code you posted. I want to check:
- Are you using the the CMakeLists.txt from the code sample? Or did you modified it (other than file names)
- What version of the compiler are you using ? (icpx --version and aocl version)
- What's your compilation target (FPGA_DEVICE)?
-Kevin
