Error: Unable to rewrite SYCL IR file
- 3 years ago
Hi @aidanom1,
Greetings, just checking in to see if there is any further doubts in regards to this matter.
Hope we have clarify your doubts.
Best Wishes
BB
Hi, I tried building one of the oneAPI samples. Here is my log
u177770@login-2:~$ qsub -I -l nodes=1:fpga_compile:ppn=2 -d .
qsub: waiting for job 2214690.v-qsvr-1.aidevcloud to start
qsub: job 2214690.v-qsvr-1.aidevcloud ready
# Date: Sat 25 Feb 2023 02:34:14 AM PST
# Job ID: 2214690.v-qsvr-1.aidevcloud
# User: u177770
# Resources: cput=75:00:00,neednodes=1:fpga_compile:ppn=2,nodes=1:fpga_compile:ppn=2,walltime=06:00:00
u177770@s001-n059:~$ git clone -b 2023.0.0 https://github.com/oneapi-src/oneAPI-samples.git
Cloning into 'oneAPI-samples'...
remote: Enumerating objects: 24137, done.
remote: Counting objects: 100% (585/585), done.
remote: Compressing objects: 100% (352/352), done.
remote: Total 24137 (delta 245), reused 521 (delta 223), pack-reused 23552
Receiving objects: 100% (24137/24137), 256.24 MiB | 3.35 MiB/s, done.
Resolving deltas: 100% (15683/15683), done.
Note: switching to 'cb1440584bb64554d573bf7b03225926c2da3651'.
You are in 'detached HEAD' state. You can look around, make experimental
changes and commit them, and you can discard any commits you make in this
state without impacting any branches by switching back to a branch.
If you want to create a new branch to retain commits you create, you may
do so (now or later) by using -c with the switch command. Example:
git switch -c <new-branch-name>
Or undo this operation with:
git switch -
Turn off this advice by setting config variable advice.detachedHead to false
Updating files: 100% (3353/3353), done.
u177770@s001-n059:~$ cd oneAPI-samples/
AI-and-Analytics/ common/ DirectProgramming/ .git/ .github/ Libraries/ Publications/ RenderingToolkit/ Tools/
u177770@s001-n059:~$ cd oneAPI-samples/DirectProgramming/
C++/ DPC++/ DPC++FPGA/ Fortran/
u177770@s001-n059:~$ cd oneAPI-samples/DirectProgramming/DPC++FPGA/
include/ ReferenceDesigns/ Tutorials/
u177770@s001-n059:~$ cd oneAPI-samples/DirectProgramming/DPC++FPGA/ReferenceDesigns/
anr/ cholesky/ crr/ decompress/ merge_sort/ qrd/
board_test/ cholesky_inversion/ db/ gzip/ mvdr_beamforming/ qri/
u177770@s001-n059:~$ cd oneAPI-samples/DirectProgramming/DPC++FPGA/ReferenceDesigns/board_test/
u177770@s001-n059:~/oneAPI-samples/DirectProgramming/DPC++FPGA/ReferenceDesigns/board_test$ mkdir build
u177770@s001-n059:~/oneAPI-samples/DirectProgramming/DPC++FPGA/ReferenceDesigns/board_test$ cd build
u177770@s001-n059:~/oneAPI-samples/DirectProgramming/DPC++FPGA/ReferenceDesigns/board_test/build$ cmake .. -DFPGA_DEVICE=/opt/intel/oneapi/intel_s10sx_pac:pac_s10
-- The CXX compiler identification is Clang 16.0.0
-- Check for working CXX compiler: /glob/development-tools/versions/oneapi/2023.0.1/oneapi/compiler/2023.0.0/linux/bin/icpx
-- Check for working CXX compiler: /glob/development-tools/versions/oneapi/2023.0.1/oneapi/compiler/2023.0.0/linux/bin/icpx -- works
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
-- Detecting CXX compile features
-- Detecting CXX compile features - done
-- Configuring the design to run on FPGA board /opt/intel/oneapi/intel_s10sx_pac:pac_s10
-- Configuring done
-- Generating done
-- Build files have been written to: /home/u177770/oneAPI-samples/DirectProgramming/DPC++FPGA/ReferenceDesigns/board_test/build
u177770@s001-n059:~/oneAPI-samples/DirectProgramming/DPC++FPGA/ReferenceDesigns/board_test/build$ make fpga
Scanning dependencies of target board_test.fpga
[ 50%] Building CXX object src/CMakeFiles/board_test.fpga.dir/board_test.cpp.o
[100%] Linking CXX executable ../board_test.fpga
warning: -reuse-exe file '/home/u177770/oneAPI-samples/DirectProgramming/DPC++FPGA/ReferenceDesigns/board_test/build/board_test.fpga' not found; ignored
aoc: Compiling for FPGA. This process may take several hours to complete. Prior to performing this compile, be sure to check the reports to ensure the design will meet your performance targets. If the reports indicate performance targets are not being met, code edits may be required. Please refer to the oneAPI FPGA Optimization Guide for information on performance tuning applications for FPGAs.
Error (23035): Tcl error:
Error (23031): Evaluation of Tcl script build/entry.tcl unsuccessful
Error: Quartus Prime Shell was unsuccessful. 2 errors, 0 warnings
For more details, full Quartus compile output can be found in files quartuserr.tmp and quartus_sh_compile.log.
Error: Compiler Error, not able to generate hardware
llvm-foreach:
icpx: error: fpga compiler command failed with exit code 1 (use -v to see invocation)
make[3]: *** [src/CMakeFiles/board_test.fpga.dir/build.make:84: board_test.fpga] Error 1
make[2]: *** [CMakeFiles/Makefile2:127: src/CMakeFiles/board_test.fpga.dir/all] Error 2
make[1]: *** [CMakeFiles/Makefile2:215: src/CMakeFiles/fpga.dir/rule] Error 2
make: *** [Makefile:170: fpga] Error 2
