Cannot view HTML GUI reports
What is that browser which you are using? It seems to me that your browser might be incompatible with the HTML report, or maybe some addon you have installed is interfering with the report. Try with a standard browser like Firefox or Chrome and make sure java script is enabled is enabled in your browser and is not blocked by any addons.
I'm using Chrome.
The issue still seems to persist. Is there any other way of generating the report? I am mainly looking for the loop and area analysis for my code.
- HRZ6 years ago
@udishaduttachowdhury Can you archive the "report" folder from one of your compiles and post it here? I can check on my side to see if there is something wrong with your report to at least rule out browser/system-specific issues.
- EBERLAZARE_I_Intel6 years ago
Similar discussion you may check out which explains similar issue seen, please take a look:
The other one:
https://community.intel.com/t5/Software-Archive/Empty-Optimization-Report/td-p/1148246
The solution was renaming issue. Which causes some directory issue which direct to the empty reports.
