Cannot run program on Stratix 10
Hi @kevin-tang,
Thank you for posting in Intel community forum and hope this message find you well.
Would recommend to check on the following steps here if you are trying to run simulation and have the mention error.
Please do also try to clean the make to see if that helps as here.
Best Wishes
BB
Hi BB,
I think there is some miscommunication, I'm trying to run a oneAPI example on the FPGA itself (not simulation).
I believe the issue is independent of the oneAPI program I'm trying to run, as some 'aocl' commands will also show these errors.
I saw some threads from other users over the last few weeks with similar issues to mine, are you able to investigate whether it is an issue with DevCloud?
https://community.intel.com/t5/Intel-High-Level-Design/cannot-run-on-fpga-hardware/m-p/1281525#M1717
Kevin
