cannot run on fpga hardware
- 5 years ago
Hi.
Now it seems to work. I didn't make any change.
Hi @scali.,
Thank you for posting in Intel community forum and hope this message find you well.
Can you share what command are being executed to compile the design?
If you are trying to run simulation, please do refer to the related troubleshooting here.
Please do let us know if that helps.
Best Wishes
BB
Hello and thank you for your reply.
Below you can find the Makefile that I am using to compile and execute.
Makefile
TARGET_EMU = fpga_emu
TARGET_HW = fpga_hardware
TARGET_REPORT = fpga_report.a
SRCS = src/template.cpp
OBJS = $(SRCS:.cpp=.o)
ETS = $(SRCS:.cpp=.d)
CXX = dpcpp
CXXFLAGS = -std=c++17
.PHONY: build build_emu build_hw report run_emu run_hw clean run
.DEFAULT_GOAL := build_emu
# Intel-supported FPGA cards
FPGA_DEVICE_A10 = intel_a10gx_pac:pac_a10
FPGA_DEVICE_S10 = intel_s10sx_pac:pac_s10
FPGA_DEVICE = $(FPGA_DEVICE_A10)
# Compile flags
EMULATOR_FLAGS = -fintelfpga -DFPGA_EMULATOR
HARDWARE_FLAGS = -fintelfpga -Xshardware -Xsboard=$(FPGA_DEVICE)
#HARDWARE_FLAGS = -fintelfpga -Xshardware
REPORT_FLAGS = $(HARDWARE_FLAGS) -fsycl-link
# Build for FPGA emulator
build: build_emu
build_emu: $(TARGET_EMU)
$(TARGET_EMU): $(SRCS)
$(CXX) $(CXXFLAGS) $(EMULATOR_FLAGS) -o $@ $^
# Generate FPGA optimization report (without compiling all the way to hardware)
report: $(TARGET_REPORT)
$(TARGET_REPORT): $(SRCS)
$(CXX) $(CXXFLAGS) $(REPORT_FLAGS) -o $@ $^
# Build for FPGA hardware
build_hw: $(TARGET_HW)
$(TARGET_HW): $(SRCS)
$(CXX) $(CXXFLAGS) $(HARDWARE_FLAGS) -fintelfpga -o $@ $^
# Run on the FPGA emulator
run: run_emu
run_emu: $(TARGET_EMU)
./$(TARGET_EMU)
# Run on the FPGA card
run_hw: $(TARGET_HW)
./$(TARGET_HW)
# Clean all
clean:
-$(RM) $(OBJS) $(TARGET_EMU) $(TARGET_HW) $(TARGET_REPORT) *.d
-$(RM) -R *.prj
Then I use the following commands to compile and execute
1)make build_emu
2)make report
3)make build_hw
4)make run_emu
5)make run_hw
The executables are compiled, but:
if I try to run on the device through 5) I get the following
Makefile:45: recipe for target 'fpga_hardware' failed
if I login to a node with Arria 10 OneAPI and then run the executable through ./fpga_hardware I obtain:
Error enumerating AFCs: not found
Segmentation fault
Do you think I am doing some mistakes?
I do not understand why, but everything was working until about a week ago.
Thanks for you help.
Best regards.
PS: the commands 1), 2) ... 5) are executed through
qsub -l nodes=1:fpga_compile:ppn=2 -d . job1.sh
or
qsub -l nodes=1:fpga_runtime:ppn=2 -d . job2.sh
and the file job.sh look like
#!/bin/bash
cd /home/my_directory
source /opt/intel/inteloneapi/setvars.sh
make run_hw
- Mickleman5 years ago
I've had exactly the same problem and symptoms for the last few weeks. Programs compiled for FPGA hardware no longer run on fpga nodes. Have you found a solution?
Marcus
- adarsh_m5 years ago
are you people still facing the issue ,i am getting segmentation fault 139 error always
