RN1
4 years agoCannot compile with Stratix10 in DevCloud and Attributes-Local Memory Performance
==== First part) Stratix10 ====
We tried different ways without luck, therefore, we attach the same steps using the interactive session in a fpga_compile machine. We tried directly with you...
BoonBengT_Altera
Moderator
4 years agoHi @RN1,
Good day, just following up on the previous clarification.
By any chances did you managed to look into the it?
Best Wishes
BB
RN1
4 years agoHello,
The OpenCL code of the kernel was sent along the report files.
We are waiting to receive your response regarding performance and local memory in oneAPI, how to optimize that simple code to achieve a similar performance than OpenCL. We didn't find any Intel/oneAPI code that shows how to properly exploit the local memory.
I attach here but you can find in the files we attached.
#include "../host/inc/matrixMult.h" #ifndef SIMD_WORK_ITEMS #define SIMD_WORK_ITEMS 16 // default value #endif __kernel __attribute((reqd_work_group_size(BLOCK_SIZE,BLOCK_SIZE,1))) __attribute((num_simd_work_items(SIMD_WORK_ITEMS))) void matrixMult( // Input and output matrices __global float *restrict C, __global float *A, __global float *B, // Widths of matrices. int A_width, int B_width) { // Local storage for a block of input matrices A and B __local float A_local[BLOCK_SIZE][BLOCK_SIZE]; __local float B_local[BLOCK_SIZE][BLOCK_SIZE]; // Block index int block_x = get_group_id(0); int block_y = get_group_id(1); // Local ID index (offset within a block) int local_x = get_local_id(0); int local_y = get_local_id(1); // Compute loop bounds int a_start = A_width * BLOCK_SIZE * block_y; int a_end = a_start + A_width - 1; int b_start = BLOCK_SIZE * block_x; float running_sum = 0.0f; // Compute the matrix multiplication result for this output element. Each // loop iteration processes one block of the matrix. for (int a = a_start, b = b_start; a <= a_end; a += BLOCK_SIZE, b += (BLOCK_SIZE * B_width)) { // Load the matrices to local memory. Note that the (x, y) indices // are swapped for A_local and B_local. This affects the reads from // A_local and B_local below and result in more efficient hardware. // // This is actually an optimization that the compiler can perform, // but is shown here for illustration purposes. A_local[local_y][local_x] = A[a + A_width * local_y + local_x]; B_local[local_x][local_y] = B[b + B_width * local_y + local_x]; // Wait for the entire block to be loaded. barrier(CLK_LOCAL_MEM_FENCE); // Do the dot product accumulation within this block. Fully unroll the loop. // As a result of the swap of indices above, memory accesses to // A_local and B_local are very efficient because each loop iteration // accesses consecutive elements. This can be seen by unrolling the // loop and analyzing the regions that are loaded: // A_local[local_y][0..BLOCK_SIZE-1] and // B_local[local_x][0..BLOCK_SIZE-1] #pragma unroll for (int k = 0; k < BLOCK_SIZE; ++k) { running_sum += A_local[local_y][k] * B_local[local_x][k]; } // Wait for the block to be fully consumed before loading the next // block. barrier(CLK_LOCAL_MEM_FENCE); } // Store result in matrix C C[get_global_id(1) * get_global_size(0) + get_global_id(0)] = running_sum; }
#ifndef MATRIXMULT_H #define MATRIXMULT_H // Block size. Affects the kernel, so if this value changes, the kernel // needs to be recompiled. #ifndef BLOCK_SIZE #define BLOCK_SIZE 64 // default value //#define BLOCK_SIZE 128 // default value #endif #endif
Kind regards
