aocl-clang.exe - Entry Point Not Found
Hi @Krus83,
Thank you for the patients, we are still trying to figure out the possible cause here.
At the meant time, would suggest to check the following:
1)possible to try to compile any example design that comes with hls installation.
2)any chances do you have more recent hls version other than 18.1 lite to test on?
3) you mention you have a similar working system, is it hls 18.1 lite/quartus 18.1/ VS 2010 Ultimate? and are you able to compile the same design there?
Hope to hear from you soon.
Best Wishes
BB
Same error
Same error.
Yes.
I have now several colleagues with the same problem and it seems to have come after windows update KB5008212. Uninstalling the update does not solve the problem.
