khyam
5 years agoAlt_sld_fab_0.alt_sld_fab_0: add_instance: Can't create component type altera_sld_agent_endpoint_tie
Arria 10 GX FPGA
Error (11176): Alt_sld_fab_0.alt_sld_fab_0: add_instance: Can't create component type altera_sld_agent_endpoint_tieoff Info (11172): invoked from within Info (11172): "add_inst...
- 5 years ago
I have resolved the issue. Please close the request service. Thank you!!!!
khyam
5 years agoSolution:
Add below command to the afu.qsf file to set stp file
set_global_assignment -name VERILOG_MACRO "INCLUDE_REMOTE_STP"
then run the design using $run.sh command
or
Add this line to filelist.txt file.
+define+INCLUDE_REMOTE_STP
Then build the design using following command
afu_synth_setup --source filelist.txt build/stp
So, It will add signal tap host instance in the design.
