AI Suite - Spatial IP outputs wrong value
- 3 months ago
Have you tested on using the system-console to run the application? https://docs.altera.com/r/docs/863373/2026.1.1/fpga-ai-suite-handbook/running-the-hostless-ddr-free-fpga-ai-suite-spatial-ip-design-example
Can you guide us on how do you generate the Spatial IP? Please provide the full step so that we can duplicate the issue
- Mads_From_Denmark3 months ago
To recreate the issue you will need the FPGA AI Suite version 2026.1.1-quartus.
Transfer the the bin and xml files called "fpga_model_spatial_1" to the docker env.
Then execute the following command:
dla_create_ip \
--ip-dir ./ip_repo \
--flow create-ip \
--arch /opt/altera/fpga_ai_suite/ubuntu/dla/example_architectures/AGX5_Simple_Spatial.arch \
--model ./fpga_model_spatial_1.xml
Now in Quartus Prime Pro 26.1, create a now project called "spatial_first". Targeting Agilex5 device A5EB013BB23BE4SR1. Then move the ip_repo folder next to the quartus folder.
Now you will need 4 files,
The Top entity called "spatial_first.vhd"
The QSF config called "spatial_first.qsf"
The system containing the AI model from the ip repo "spatial.qsys"
The signaltaptest.stp to see the signal tap output
The files I have uploaded here on my github, I can also upload the entire project if you will accept that.
https://github.com/madskost/spatial_first
