User1582192733150209
6 years agoQuestions about 10GE mac configuration and CRC inserting enabling in eth_e2e_e10
Hello Sir/madam, For design example eth_e2e_e10, 1,May I know where I can check the c code or SV code for 10G mac configuration in design example eth_e2e_e10? 2,As to CRC checksum, I have noticed ...
JohnT_Altera
6 years agoHi,
You will need to modify the RTL code as the design example is using Pattern Generator and Pattern Monitor in order to verify the Ethernet packats. In the RTL code, you will observed Avalon_st_gen and Avalon_st_mon.
