User1582192733150209
6 years agoQuestions about 10GE mac configuration and CRC inserting enabling in eth_e2e_e10
Hello Sir/madam, For design example eth_e2e_e10, 1,May I know where I can check the c code or SV code for 10G mac configuration in design example eth_e2e_e10? 2,As to CRC checksum, I have noticed ...
Deshi_Intel
6 years agoHi Jim,
Sorry, I am not aware you are referring to Intel PAC Arria10gx 10G Ethernet example design issue.
I am not familiar with PAC card but I google and find out some info on this example design that perhaps you can checkout.
You can learned more about the 10G Ethernet IP architecture in below link :
As for the example design debug, below is the doc
- https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug-dex-afu-10gbe.pdf
- Just wonder have you try run the example design directly without modification to check if it works first ?
- Does it failed on all 4 10G Ethernet link or just 1 or 2 link ?
- Other generic Ethernet debug suggestion will be like
- test out internal loop back mode
- Then follow by external loopback mode (using QSFP loopback module)
- finally only you proceed to try out on wireshark to slowly isolate where is the issue
dlim
