DongWang-BJTU
6 years agoQuestion on the new features of OpenCLSDK v20.1
Hi, I have recently noticed that in SDK v20.1 it is that the following new feature is available: "Enabled stall enable clusters pragma to reduce local memory usage by removing FIFO instantiations an...
- 6 years ago
It seems like there is a documentation problem as there is no information for this feature. I had reported to developer to check on this problem.
You could able to apply this feature by using __attribute__((stall_enable)) to a kernel, then the compiler should only create stall-enable clusters in that kernel.
MEIYAN_L_Intel
6 years agoHi,
I am glad that the information provided can give help to you.
