Question on the new features of OpenCLSDK v20.1
- 6 years ago
It seems like there is a documentation problem as there is no information for this feature. I had reported to developer to check on this problem.
You could able to apply this feature by using __attribute__((stall_enable)) to a kernel, then the compiler should only create stall-enable clusters in that kernel.
I had checked the document on the "stall_enable" fucntion and I am not able to find the information for this function.
I am checking the information internally "Enabled stall enable clusters pragma to reduce local memory usage by removing FIFO instantiations and latency between functions".
For your information, I am able to find information with HLS reference manual guide in page 148: https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/hls/mnl-hls-reference.pdf
by using the syntax "hls_use_stall_enable_clusters"
- DongWang-BJTU6 years ago
Hi, thanks for the quick reply.
How do I enable this feature in OpenCL kernel code rather than HLS ? which pragma should I use ?
