Avinash201040
2 years agoquartus compilation error for `include "sr_def_param.vh"
hiii, i have quartus project in which i have qsys_top.qsys. In qsys_top.qsys , i have instantiated a custom ip , radio_config.ip. the radio_config.ip is created using a rtl file radio_config.v i ha...
RichardT_altera
2 years agoIt could be due to the Quartus tool and the Platform Designer tool are searching the files differently.
You can try to use the SEARCH_PATH assignment to define the project libraries (add these to the .QSF file). You can have multiple SEARCH_PATH assignments. However, you can specify only one source directory for each SEARCH_PATH assignment.
Example:
set_global_assignment -name SEARCH_PATH "../other_dir/library1"
set_global_assignment -name SEARCH_PATH "../other_dir/library2"
set_global_assignment -name SEARCH_PATH "../other_dir/library3"
Richard Tan
