Project using 10AS066H2F34I1HG device
I'm working on a project at the university using the device 10AS066H2F34I1HG from arria 10, I needed to compile this project, can I compile it on devcloud?
Liliane
Hi Liliane,
Yes, you can compile it on DevCloud for all Arria 10 devices.
You can refer here on how you can do that: https://techdecoded.intel.io/quickhits/introduction-to-using-fpga-on-intel-devcloud/#gs.xr2eza
Additionally it's also available on the Intel Software YouTube channel: https://www.youtube.com/watch?v=E8q5dhO8Pjw
Let me know if you have any more queries,
Nurina
PS: If there's any helpful answer given by the community or Intel Support, feel free to give Kudos.
- Nurina
Hi Liliane,
Nurina
- lilianegade4
Hi Nurina,
thank you so much for the answer, it helped a lot.
Just one more question, as I use the device 10AS066H2F34I1HG in my project, I can only compile it on quartus prime pro. However, the 30-day trial version does not generate the programming files, are there any university programs that I can generate the .sof file for this fpga model?
Once again thank you for your attention.
Liliane
- Nurina
Hi Liliane,
You can try using Quartus Prime Lite. At the programmer, select 10AS066H2F34. It should work fine, as it would target the device of this family.
For clarification, page 14 of this document describes the meaning of the alphabets and numbers on the device name: https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/arria-10/a10_overview.pdf
Is there any more questions you'd like to ask?
Nurina
- lilianegade4
Hi Nurina,
Thank you so much for the tips! It worked out.
Liliane
- Nurina
Hi Liliane,
Nurina
