Problem mixing FPGA and CPU kernels that resort to accessors for inter-device comms
- 5 years ago
This issue of CL_INVALID_BINARY when compiling with the -fintelfpga flag while trying to run on CPU + FPGA can be solved by using the following flag in place of -fintelfpga: -fsycl-targets=spir64_fpga-unknown-unknown-sycldevice,spir64-unknown-unknown-sycldevice. The full command would then be: dpcpp -fsycl-targets=spir64_fpga-unknown-unknown-sycldevice,spir64-unknown-unknown-sycldevice vadd.cpp -o vadd.emu
This stems from the fact that the -fintelfpga flag instructs the compiler to perform an offline/AOT compilation which specifically targets an fpga device only (similar to CPU offline compilation). You can see more on targeting multiple platforms here, which gives examples for FPGA emulation/hardware compiles with separate source files for the CPU and FPGA kernels.
Best regards.
Hi George,
It works perfect now!
Thank you very much.
Best regards.
Thank you George!
It actually works in emulation mode. I also compiled the final bitstream as explained below, but at runtime I got this error message:
terminate called after throwing an instance of 'cl::sycl::feature_not_supported' what(): SPIR-V online compilation is not supported in this context -59 (CL_INVALID_OPERATION) /var/spool/torque/mom_priv/jobs/784102.v-qsvr-1.aidevcloud.SC: line 11: 15844 Aborted bin/fpga-hw
I used this script, compile_fpga_hw.sh, to compile:
source /opt/intel/inteloneapi/setvars.sh rm -rf bin/fpga-hw.o #/bin/echo "##" $(whoami) is compiling DPC++ example for FPGA hardware dpcpp -fsycl-targets=spir64_fpga-unknown-unknown-sycldevice,spir64-unknown-unknown-sycldevice -c lab/vector-add-fpga.cpp -o bin/fpga-hw.o dpcpp -fsycl-targets=spir64_fpga-unknown-unknown-sycldevice,spir64-unknown-unknown-sycldevice bin/fpga-hw.o -Xshardware -Xsboard=intel_a10gx_pac:pac_a10 -Xsparallel=8 -o bin/fpga-hw
And launched with this other script, just in case anyone want to reproduce it:
qsub -l nodes=1:ppn=2:fpga_compile -d . scripts/compile_fpga_hw.sh
According to the Programming Guide, two different files, one for the FPGA and a different one for the CPU, should be compiled separately and linked afterwards. I'd rather avoid this extra burden if at all possible, so I wonder what would be the compilation flags to get it running using a single source file.
Thanks once again!
