DongWang-BJTU
7 years agoPerformance difference between OpenCL 18.1 Std and Pro for FPGA ?
I was compiling the same kernel code by using both v18.1 std and pro. For the standard version, I could achieve a fmax around 220 MHz, but for pro version, the fmax is only 190 MHz. I further compar...
MuhammadAr_U_Intel
Contributor
7 years agoCould you give it a try with latest OpenCL compiler release 19.1, if problem persists you may share the kernel codes and steps to replicate the issue in private message and I can help to feedback this to Engineering team.
Arslan
