PBEH-453561874321(MPN:5SGSMD5K2F40I2N) FA requirement from Flex(suzhou)
Hi ,
Can I confirm again the pin name for 5SGSMD5K2F40I2N having low resistance value to GND?
Do we have more granular information aside from the device has low resistance? Do you observe other functional failure information?
Wani
I had replied your questions.
Do you have any other questions?
Would you please arrange the failure analysis?
- Zawani_M_Intel5 years ago
AU31&AW33 , AU28&AW30 are VCC pin. VCC pins short to ground is one of the symptoms of EOS.
In order to avoid electrical damage, the device should always be handled in a static-free environment and all the input signals should remain within specified limits, as recommended in the PSG Data Book and associated application notes, at all times.For your information, EOS is fall under mishandling issue.
Wani
- FA-requirement5 years ago
Flex has strict ESD control throughout the manufacturing process, and the personnel operation also meets the ESD requirements, so we don't think the short circuit is caused by EOS. We hope you can arrange the failure analysis and find the root cause.
I need some confidential info to validate further. Hence we will continue this case there.
Wani
