FA-requirement
5 years agoPBEH-453561874321(MPN:5SGSMD5K2F40I2N) FA requirement from Flex(suzhou)
PBEH-453561874321(MPN:5SGSMD5K2F40I2G) failed on ICT station at Flex because the resistance value of 3.0V to GND is lower than normal. The defect rate is about 4%(=9/224).
We need manufacturer to ...
Zawani_M_Intel
5 years agoHi ,
Can I confirm again the pin name for 5SGSMD5K2F40I2N having low resistance value to GND?
Do we have more granular information aside from the device has low resistance? Do you observe other functional failure information?
Wani
FA-requirement
5 years agoWe have two kinds of failure as below:
Pins AU31&AW33 to GND low resistance (around low than 500 Ohm), the defective products is 2pcs.
Pins AU28&AW30 to GND low resistance (around low than 1.2kOhm), the defective product is 1pc.
This fail will impact our ICT test of PCBA.
Could we send these defective products to you to do failure analysis?
Please help to arrange the FA requirement.
