PAC Arria 10 GX, reconfiguration not working on 1.2PV
Hi @HKim27
Sorry i missed your reply. Thank you for following up.
Could you run the below steps:
Could you reboot your system?
Source init_env.sh
aocl install
program a hello_world.aocx to initialize the board
aocl diagnose (it should show the status as "Passed")
Then go back to performing: https://www.intel.com/content/altera-www/global/en_us/index/documentation/fvf1521490619217.html#nms1523294913946
make sure you have copied the vector_add.aocx into the "bin" folder
cp $OPAE_PLATFORM_ROOT/opencl/vector_add.aocx ./bin
Also, check if you have set your hugepages.
If this still fails, please confirm you meet the system requirement: https://www.intel.com/content/www/us/en/programmable/documentation/iyu1522005567196.html#oeh1528996494398
- HKim276 years ago
I finally found the solution. (after 8 month!!!)
Initialization script inside Intel Acceleration Stack Version 1.2 (inteldevstack/init_env.sh) has this line:
export CL_CONTEXT_COMPILER_MODE_INTELFPGA=3According to the documentation, this environment variable prevent reconfiguration during OpenCL host execution.
By unsetting this, reconfiguration works well.
