HKim27
7 years agoPAC Arria 10 GX, aoc compilation error
Hi, all I installed acceleration stack, followed guide to install bsp and setup environment variables. "aocl diagnose" detects device well, and pre-compiled aocx examples run well. But when I try ...
HRZ
7 years agoYour problem is likely due to a version mismatch between your BSP and the OpenCL compiler you are using, rather than the OpenCL kernel itself. Can you post the version of BSP, quartus and aoc you are using and also attach the quartus_sh_compile.log file generated during your failed compilation?
