WWP00
6 years agoOptimizer FAILED with no explanation
Ran: $ time ~/software/intelFPGA_pro/19.2/hld/bin/aoc -v -fpc -fp-relaxed kernel2.cl -o kernel2.aocx -board=s10gx aoc: Environment checks are completed successfully. aoc: Cached files in /var/tmp/...
HRZ
6 years agoHow long does it take from when you run the command until you receive the error? If it takes more than an hour, then your kernel is likely too complex for the compiler to process. The "-high-effort" is for placement and routing and will not affect your case; your kernel compilation is failing in the OpenCL to HDL conversion step, not placement and routing.
WWP00
6 years agoAbout 90 minutes
