OpenCL: What's best practice for replicating a task kernel in-FPGA?
I think you are referring to external memory bandwidth and not PCI-E bandwidth because PCI-E bandwidth is determined by the physical features of the PCI-E connection on your FPGA board and motherboard (number of lanes and PCI-E version) and its effective throughput is determined by multiple factors such as the size of your data transfer and the efficiency of the PCI-E driver; these are not really factors that can be controlled by the programmer.
Assuming that you refer to external memory bandwidth, then your problem has a simple solution: you need to use loop unrolling to vectorize your single work-item kernel. Loop unrolling will not only increase the amount of computation that is done by your kernel per cycle, it will also lead to consecutive memory accesses in your loop being coalesced into larger accesses by the compiler which will result in better utilization of the external memory bandwidth. Loop unrolling in single work-item kernels gives a behavior similar to the SIMD attribute in NDRange kernels.
- JSchr206 years ago
Since this is the forum thread I started, I'll consolidate my 'progress' and followup question here. I followed your advice in your reply here: https://forums.intel.com/s/question/0D70P000006i6SySAI
I now do have a version of my code working, which has a non-autorun kernel that fetches the data out of memory, an autorun kernel that operates on it, and another non-autorun kernel that writes the results back to memory, all interconnected with Intel channels and access with blocking reads and writes.
However, when I try to add a num_compute_units attribute to my kernels (and add in the necessary code to make use of the compute unit IDs), I get this error:
Initializing OpenCL
Platform: Intel(R) FPGA SDK for OpenCL(TM)
Using 1 device(s)
EmulatorDevice : Emulated Device
Using emulator, adding '_em' to output filename
Binary filename = my_autorun_em
Using AOCX: my_autorun_em.aocx
Launching for device 0 (4 elements)
Hey, I'm comp_id 0
I'm operating with NUM_LIMBS = 4 and NUM_COMPUTE_UNITS = 1.
about to read first operand
terminate called after throwing an instance of 'std::bad_alloc'
what(): std::bad_alloc
Aborted
I'm guessing my other kernels aren't relevant since they haven't even been started yet. I've attached the code snippet of my autorun kernel I'm guessing is relevant. (Pardon the .c extension, amazingly, we can't upload .cl files here!) Is it obvious what I'm doing wrong?
I am using legacy emulation, by the way. When I try fast emulation, I get a seg fault.
Well, things have gotten weirder.
The error I posted above is coming from legacy emulation on my local compute server using aoc 20.1.
We don't have fast emulation working yet on our local server.
On the dev cloud, where can use fast emulation, I'm uniformly getting a seg fault, as I described above. In addition, I noticed today that one of my kernels reports a compute ID of -1 a few print statements before the seg fault.
However, also on the dev cloud, if I use legacy emulation with num_compute_units=1, it works. My program runs and declares PASS on valid answers.
If I run on the dev cloud with num_compute_units=2, legacy emulation mostly works, but it hangs without completing. Fast emulation seg faults as before.
So anyhow. I'm going to hunt for more clues.
- HRZ6 years ago
I am not sure if this is an artifact in your snippet but it seems you are reading from and writing to channels with the same ID as the compute unit (albeit with different channel names). One would typically read from a previous compute unit and write to a following one, you should not read from and write to the same channel ID in the same compute unit. Another potential pitfall is channel ordering; the compiler will freely re-order channel operations and if there is a cycle of channels in your design, you can potentially run into a dead-lock unless you enforce channel re-ordering using barriers as described in Intel's documentation. Finally, it seems v20.1 is quite problematic based on reports from you and other people in the forum, you might want to consider switching to v19.4 on your local machine and see if you would run into the same problems. Assuming that you can create a minimal example that reproduces the issue and post it here, it will be easier to find potential issues in the code.
