FPorr
7 years agoOpenCL software emulation crashes when the Kernel uses more than 6MByte of memory
Hello, the OpenCL software emulation crashes with a segmentation fault when the kernel utilizes more than 6MByte of memory. Example: uchar arr[128*128*384]; // 6MByte -- Works
uchar arr[128*128*38...
FPorr
7 years agoHi,
I managed to solve the problem. It did not work because I forgot to install a device ... 😟
Anyway, using the fast emulator indeed removed the problem, the application no longer crashes for data > 6MB.
Thank you for your assistance.
