FPorr
7 years agoOpenCL software emulation crashes when the Kernel uses more than 6MByte of memory
Hello, the OpenCL software emulation crashes with a segmentation fault when the kernel utilizes more than 6MByte of memory. Example: uchar arr[128*128*384]; // 6MByte -- Works
uchar arr[128*128*38...
FPorr
7 years agoHi,
I am sorry for the late response. I installed 19.1 but trying to compile any kernel using the fast emulator fails with:
Error: OpenCL kernel compilation FAILED
The ioc.log contains the following lines:
Using build options: -cl-std=CL1.2 -Xclang -Wuninitialized -I "/home/user/vector_add/device"
Failed to get platform id...: 0 (CL_SUCCESS)
Compilation failed!
Any thoughts on what might be the problem?
