FPorr
7 years agoOpenCL software emulation crashes when the Kernel uses more than 6MByte of memory
Hello, the OpenCL software emulation crashes with a segmentation fault when the kernel utilizes more than 6MByte of memory. Example: uchar arr[128*128*384]; // 6MByte -- Works
uchar arr[128*128*38...
KhaiChein_Y_Intel
7 years agoHi,
A lot has changed in the emulator since 18.0, not only in the old emulator flow (now called legacy emulator), but there is now a new emulator that replaces it in 19.1 (the fast emulator). Can you try this in 19.1 with the new fast emulator?
