FPorr
7 years agoOpenCL software emulation crashes when the Kernel uses more than 6MByte of memory
Hello, the OpenCL software emulation crashes with a segmentation fault when the kernel utilizes more than 6MByte of memory. Example: uchar arr[128*128*384]; // 6MByte -- Works
uchar arr[128*128*38...
FPorr
7 years agoHi,
thank you for the reply, I attached a simple test case to reproduce the error.
The build commands I used were:
# Host application
make
# Kernel
aoc -march=emulator krnl.cl -o bin/krnl_emu.aocxand for execution:
CL_CONTEXT_EMULATOR_DEVICE_INTELFPGA=1 bin/host bin/krnl_emu.aocxDepending on which size define is enabled in krnl.cl, the application either crashes or executes.
