paolop
4 years agoopenCL memory map
Hi, I am trying to interface a design (gzip) implemented through the OpenCL flow. I went successfully through all the steps, till generating the green bitstream which ran properly on a board equipped...
aikeu
4 years agoHi paolop,
I get the info from the team that what you are trying to work on is to convert the code from OpenCL to RTL coding which is not supported.
It is required to use the OpenCL kernel instead or else it is required to rewrite the AFU using RTL only can control the DMA and etc.
Do let me know if you have any question from the above statement.
Aik Eu
